P1400
Manufacturer Specific Definitions for P1400
Audi | Exhaust gas recirculation (EGR) valve/solenoid, Bank 1 - circuit malfunction |
Bmw | Camshaft Position Actuator 'A' Control Circuit Signal Low Bank 1 |
Buick | Cold start emission control -malfunction |
Cadillac | Cold start emission control -malfunction |
Chevrolet | Cold start emission control -malfunction |
Chrysler | Manifold differential pressure (MOP) sensor,EGR system -circuit malfunction |
Citroen | DPFE Circuit Low Input |
Daewoo | Egr Solenoid |
Dodge | Manifold differential pressure (MOP) sensor,exhaust gas recirculation (EGR) system -circuit malfunction |
Eagle | Manifold differential pressure (MOP) sensor,EGR system -circuit malfunction |
Ford | Differential Pressure Feedback Electronic Sensor Circuit Low Voltage |
Gmc | Cold start emission control -malfunction |
Gm | Cold start emission control -malfunction |
Hummer | Cold start emission control -malfunction |
Hyundai | Manifold Diff. Pressure Sensor |
Infiniti | Exhaust gas recirculation (EGR) valve - voltage incorrect |
Isuzu | Cold start emission control – malfunction |
Jaguar | Exhaust gas recirculation (EGR) solenoid - position control |
Jeep | Manifold Differential Pressure sensor condition |
Kenworth | P1400 - EGR high rate fault when estimated EGR rate is greater than a APV |
Land Rover | Exhaust gas pressure sensor – voltage low |
Lexus | Throttle position (TP) sensor 2 – circuit malfunction |
Lincoln | Exhaust gas recirculation (EGR) pressure sensor circuit malfunction, low input |
Mazda | Differential pressure feedback sensor – low voltage detected |
Mercedes-Benz | Exhaust gas recirculation (EGR) solenoid -circuit malfunction |
Mercury | Exhaust gas recirculation (EGR) pressure sensor circuit malfunction, low input |
Mini | Heated Catalyst Battery Voltage or Current too Low During Heating Bank 1 |
Mitsubishi | Manifold absolute pressure (MAP) sensor- circuit malfunction |
Nissan | Exhaust gas recirculation (EGR) system/ evaporative emission (EVAP) canister purge system – valve malfunction |
Peterbilt | P1400 - EGR high rate fault when estimated EGR rate is greater than a APV |
Peugeot | DPFE Circuit Low Input |
Pontiac | Cold start emission control – malfunction |
Saab | Cold start emission control – malfunction |
Saturn | Cold start emission control -malfunction |
Subaru | Fuel tank vent valve – circuit malfunction voltage low |
Toyota | Throttle position (TP) sensor 2 - circuit malfunction |
Volvo | Outside air temperature sensor – signal low |
Volkswagen | Exhaust gas recirculation (EGR) valve/ solenoid, circuit malfunction |
