P1390
Manufacturer Specific Definitions for P1390
Acura | G-sensor - intermittent voltage low |
Buick | Wheel Speed Sensor 1 G-Sensor Circuit |
Cadillac | Wheel Speed Sensor 1 G-Sensor Circuit |
Chevrolet | Wheel Speed Sensor 1 G-Sensor Circuit |
Chrysler | Crankshaft position (CKP) sensor/camshaftposition (CMP) sensor -signal synchronisation |
Citroen | Octane Adjust Pin Out Of Self Test Range |
Dodge | AIR system -flow excessively high or low |
Eagle | Timing belt jumped 1 tooth or more |
Ford | Octane Adjust Out of Self-Test Range |
Freightliner | AIR system -flow excessively high or low |
Gm | Wheel Speed Sensor 1 G-Sensor Circuit |
Honda | G-sensor - intermittent voltage low |
Isuzu | G-force sensor – intermittent voltage low |
Jeep | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor -signal synchronisation |
Lincoln | Octane adjustment |
Mazda | Octane adjust – out of self-test range |
Mercury | Octane adjustment |
Mitsubishi | Timing Belt Skipped 1 Tooth Or More |
Peugeot | Octane Adjust Pin Out Of Self Test Range |
Plymouth | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor -signal synchronisation |
Saab | Misfire detected, random – fuel level low |
We have not gotten around to publishing a technical guide specifically for P1390 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
