P1385
Reading P1385 on your car
P1385 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1385
| Make | Fault Location |
| Audi | Engine control module (ECM) - defective |
| Bmw | Inlet camshaft control system, camshaft position - plausibility |
| Citroen | Variable Cam Timing Solenoid B Malfunction |
| Daewoo | Variable reluctance sensor, without ABS – circuit malfunction |
| Ford | Variable Cam Timing Solenoid 'B' Malfunction |
| Lincoln | Camshaft position (CMP) actuator, bank 2 circuit malfunction |
| Mazda | Camshaft Position Actuator Circuit Bank 2 |
| Mercedes-Benz | Knock sensor (KS) 2, bank 2 – malfunction |
| Mercury | Camshaft position (CMP) actuator, bank 2 circuit malfunction |
| Peugeot | Variable Cam Timing Solenoid B Malfunction |
| Porsche | Knock Sensor 2 |
| Volkswagen | Engine control module (ECM) - defective |
We have not gotten around to publishing a technical guide specifically for P1385 yet.
