P1381
Manufacturer Specific Definitions for P1381
Acura | Camshaft position (CMP) range/ performance problem |
Bmw | Battery temperature sensor circuit – electrical fault |
Buick | Rough road signal -no communication from antilock brake system (ASS) CANdata bus |
Cadillac | Rough road signal -no communication from antilock brake system (ASS) CAN data bus |
Chevrolet | Antilock brake system (ABS)/traction control system (TCS), rough road signal to engine control module (ECM) -no communication |
Citroen | Variable Cam Timing Overadvanced (Bank #1)/ Misfire Detected - No Communication with BCM |
Daewoo | Rough road signal – no communication from ABS CAN data bus |
Dodge | Crank Position System Variation Not Learned |
Ford | Variable Cam Timing Over Advance Bank 1 |
Gmc | Antilock brake system (ABS)/traction control system (TCS), rough road signal to ECM -nocommunication |
Gm | Engine Misfire Detected, No EBCM/PCM Serial Data |
Honda | Camshaft position (CMP) sensor- intermittent signal |
Hummer | Antilock brake system (ABS)/traction control system (TCS), rough road signal to ECM -no communication |
Isuzu | ECM to ABS communication – misfire detected |
Jaguar | Variable Cam Timing Over Advance Bank 1 |
Land Rover | Camshaft position (CMP) actuator – timing over advanced |
Lincoln | Camshaft position (CMP) actuator, bank 1 timing over advanced |
Mazda | Camshaft Position Timing Over Advanced Bank 1 |
Mercury | Camshaft position (CMP) actuator, bank 1 timing over advanced |
Oldsmobile | Rough road signal -no communication from ASS CAN data bus . |
Peugeot | Variable Cam Timing Overadvanced (Bank #1)/ Misfire Detected - No Communication with BCM |
Pontiac | Antilock brake system (ABS)/traction control system (TCS). rough road signal to ECM – no communication |
Saab | Antilock brake system (ABS)/traction control system (TCS), rough road signal to ECM – no communication |
Saturn | Antilock brake system (ABS)/traction control system (TCS). rough road signal to ECM -nocommunication |
We have not gotten around to publishing a technical guide specifically for P1381 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
