P1380
Manufacturer Specific Definitions for P1380
Buick | Rough road signal -signal error |
Cadillac | Rough road signal -signal error |
Chevrolet | Antilock brake system (ABS)/traction control system (TCS), rough road signal to engine control module (ECM) -malfunction |
Citroen | Misfire Detected - Rough Road Data Not Available |
Daewoo | Rough road signal – malfunction |
Dodge | Vacuum Leak Found IAC Fully Seated |
Ford | Variable Cam Timing Solenoid 'A' Circuit Condition |
Gmc | Antilock brake system (ABS)/traction controlsystem (TCS), rough road signal to ECM -malfunction |
Gm | EBTCM DTC Detected, Rough Road Data Unusable |
Honda | Engine control module (ECM)/ABS control module, rough road signal - communication fault |
Hummer | Antilock brake system (ABS)/traction control system (TCS), rough road signal to ECM -malfunction |
Isuzu | ECM to ABS communication – unusable signal |
Land Rover | Camshaft position (CMP) actuator- circuit malfunction |
Lincoln | Camshaft position (CMP) actuator -circuit malfunction |
Mazda | Camshaft Position Actuator Circuit Bank 1 |
Mercedes-Benz | Cylinder cut-out system OFF -one inlet valve of a cylinder is not opening |
Mercury | Camshaft position (CMP) actuator, bank 1 circuit malfunction |
Oldsmobile | Rough road signal -signal error |
Peugeot | Misfire Detected - Rough Road Data Not Available |
Pontiac | Antilock brake system (ABS)/traction control system (TCS), rough road signal to ECM – malfunction |
Saab | Antilock brake system (ABS)/traction control system (TCS), rough road signal to ECM – malfunction |
Saturn | Rough road signal error |
Suzuki | Misfire Detected- Rough Road Data Not Available |
We have not gotten around to publishing a technical guide specifically for P1380 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
