P1372
P1372 | Cylinder 6 Ignition Circuit Short To Ground (AUDI, VOLKSWAGEN) Crankshaft Position Sensor A-B Correlation Conditions (BUICK, CADILLAC, CHEVROLET, GMC, OLDSMOBILE) Crankshaft Position Sensor Signal Malfunction (HYUNDAI, KIA) Ignition Coil Cylinder 2 Early Activation (JAGUAR) |
Other Manufacturer Specific Definitions for P1372
Crankshaft Position Sensor A-B Correlation Conditions (GM)Ignition coil/amplifier, cylinder 6 - short to ground (Volkswagen)
Ignition coil/amplifier, cylinder 6 - short to ground (Audi)
Crankshaft Position Sensor A-B Correlation Conditions (Buick)
Crankshaft pOSition (CKP) sensor (Cadillac)
Crankshaft Position Sensor A-B Correlation Conditions (Chevrolet)
Vehicle speed sensor (VSS) – range/performance problem (Hyundai)
Ignition coil, cylinder 2 - early activation (Jaguar)
Crankshaft position (CKP) sensor – signal malfunction (Kia)
Ignition coil, cylinder 2 – early activation (Land Rover)
Crankshaft position (CKP) sensor (Oldsmobile)
Crankshaft position (CKP) sensor (Pontiac)
BAT Team Discussions for P1372
- 98 Seville electrical problem and stalling
Wow! Donations are great! Without them it's HIGHLY UNLIKELY this site would be able to continue for the benefit of us al... and we're always glad to go the extra mile to help those who help this site. As for the stalling problem, if the engine is running fine - nice and smooth and all - and then j... - 01 deville hesitation stall list of codes
hopefully someone can help me out. i have a 2001 cadillac deville engine code "Y". It came in for a hesitation and stall when hot but only when the car is up to temp and check engine light. the original codes P0108- map orbaro pres signal high P0335 CKP ssensor 'a' circuit problem P0336 Ckp se...
Leave a Reply
