P1366
Reading P1366 on your car
P1366 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1366
AcuraCamshaft position (CMP) intermittent
AudiIgnition coil/amplifier, cylinder 4 - short to ground
BuickIgnition Control Cylinder 6 Not Toggling AFter Enable
CadillacIgnition Control Cylinder 6 Not Toggling AFter Enable
ChevroletIgnition Control Cylinder 6 Not Toggling After Enable
CitroenIgnition Spare
GmIgnition Control Cylinder 6 Not Toggling After Enable
HondaCamshaft position (CMP) sensor B/TDC   sensor 2 – intermittent signal
JaguarIgnition coil, cylinder 6 - no activation
LexusCamshaft position (CMP) actuator, bank 1, circuit E – circuit malfunction
Mercedes-BenzCylinder cut-out system, throttle switch-over valve – malfunction
OldsmobileIgnition control module (ICM) -ignition coil 6circuit voltage low
PeugeotIgnition Spare
Toyota'E' Camshaft Position Actuator Circuit Open/Low/High Bank 1
VolkswagenIgnition coil/amplifier, cylinder 4 - short to ground
We have not gotten around to publishing a technical guide specifically for P1366 yet.
