P1365
Manufacturer Specific Definitions for P1365
Audi | Ignition coil/amplifier, cylinder 4 - short to positive |
Bmw | Engine off timer – implausible signal |
Buick | Ignition Control Cylinder 5 Not Toggling After Enable |
Cadillac | Ignition Control Cylinder 5 Not Toggling After Enable |
Chevrolet | Ignition Control Cylinder 5 Not Toggling After Enable |
Citroen | Ignition Coil Secondary Circuit Failure |
Ford | Ignition Coil Secondary Circuit Failure |
Gm | Ignition Control Cylinder 5 Not Toggling After Enable |
Jaguar | Ignition coil, cylinder 5 - no activation |
Land Rover | Ignition coil, secondary – circuit malfunction |
Lexus | Camshaft position (CMP) actuator, bank 2, circuit C – circuit malfunction |
Lincoln | Ignition Coil Secondary Circuit Failure |
Mazda | Ignition coil – secondary circuit malfunction |
Mercury | Ignition Coil Secondary Circuit Failure |
Oldsmobile | Ignition control module (ICM) -ignition coil 5 circuit voltage low |
Peugeot | Ignition Coil Secondary Circuit Failure |
Volkswagen | Ignition coil/amplifier, cylinder 4 - short to positive |
