P1364
Manufacturer Specific Definitions for P1364
Audi | Ignition coil/amplifier, cylinder 4 - open circuit |
Bmw | Manifold differential pressure circuit – signal high |
Buick | Ignition Control Cylinder 4 Not Toggling After Enable |
Cadillac | Ignition Control Cylinder 4 Not Toggling After Enable |
Chevrolet | Ignition Control Cylinder 4 Not Toggling After Enable |
Citroen | Ignition Coil Primary Circuit Failure |
Ford | Ignition Coil Primary Circuit Fault |
Gm | Ignition Control Cylinder 4 Not Toggling After Enable |
Jaguar | Ignition coil, cylinder 4 - no activation |
Land Rover | Ignition coil, primary – circuit malfunction |
Lexus | Camshaft position (CMP) actuator, bank 1, circuit C – circuit malfunction |
Lincoln | Ignition coil, primary -circuit malfunction |
Mazda | Ignition coil – primary circuit malfunction |
Mercury | Ignition Coil Primary Circuit Fault |
Oldsmobile | Ignition control module (ICM) -ignition coil 4circuit voltage low |
Peugeot | Ignition Coil Primary Circuit Failure |
Toyota | 'C' Camshaft Position Actuator Circuit Open/Low/High Bank 1 |
Volkswagen | Ignition coil/amplifier, cylinder 4 - open circuit |
