P1363
Manufacturer Specific Definitions for P1363
Audi | Ignition coil/amplifier, cylinder 3 - short to ground |
Bmw | Manifold differential pressure circuit – signal low |
Buick | Ignition Control Cylinder 3 Not Toggling After Enable |
Cadillac | Ignition Control Cylinder 3 Not Toggling After Enable |
Chevrolet | Ignition control module (ICM) -ignition coil 3 circuit voltage low |
Citroen | Ignition Coil D Secondary Circuit Malfunction |
Ford | Ignition Coil 'D' Secondary Circuit Malfunction |
Gm | Ignition Control Cylinder 3 Not Toggling After Enable |
Jaguar | Ignition coil, cylinder 3 - no activation |
Land Rover | Ignition coil, cylinder 3 – no activation |
Lexus | Camshaft position (CMP) actuator, bank 2, circuit B – circuit malfunction |
Lincoln | Ignition Coil 'D' Secondary Circuit Malfunction |
Mazda | Ignition coil D – secondary circuit malfunction |
Mercury | Ignition Coil 'D' Secondary Circuit Malfunction |
Oldsmobile | Ignition control module (ICM) -ignition coil 3circuit voltage low |
Peugeot | Ignition Coil D Secondary Circuit Malfunction |
Toyota | 'B' Camshaft Position Actuator Circuit Open/Low/High Bank 2 |
Volkswagen | Ignition coil/amplifier, cylinder 3 - short to ground |
We have not gotten around to publishing a technical guide specifically for P1363 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
