P1360
Manufacturer Specific Definitions for P1360
Audi | Ignition coil/amplifier, cylinder 2 - short to ground |
Bmw | Battery temperature sensor circuit – current error |
Buick | Ignition Control Circuit Group 2 |
Cadillac | Ignition control module (ICM) bank 2 -circuit malfunction |
Chevrolet | Ignition Control Circuit Group 2 |
Citroen | Ignition Coil A Secondary Circuit Malfunction |
Dodge | Oxygen sensors, downstream -signal mismatch |
Ford | Ignition Coil 'A' Secondary Circuit Malfunction |
Freightliner | Oxygen sensors, downstream -signal mismatch |
Gm | Ignition Coil Group 2 Control Circuit Conditions |
Land Rover | Ignition coil A, secondary – circuit malfunction |
Lexus | Camshaft position (CMP) actuator, bank 1, circuit A – circuit malfunction |
Lincoln | Ignition Coil 'A' Secondary Circuit Malfunction |
Mazda | Ignition coil A – secondary circuit malfunction |
Mercedes-Benz | Cylinder cut-out system OFF, cylinder 3 -exhaust valve not opening |
Mercury | Ignition Coil 'A' Secondary Circuit Malfunction |
Oldsmobile | Ignition control module (lCM) bank 2 -circuit malfunction |
Peugeot | Ignition Coil A Secondary Circuit Malfunction |
Toyota | 'A' Camshaft Position Actuator Circuit Open/Low/High Bank 1 |
Volvo | Ignition coil, cylinder 6, primary – signal low |
Volkswagen | Ignition coil/amplifier, cylinder 2 - short to ground |
We have not gotten around to publishing a technical guide specifically for P1360 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
