P1359
Manufacturer Specific Definitions for P1359
Acura | Crankshaft position (CKP) sensor - connector disconnection |
Audi | Ignition coil/amplifier, cylinder 2 - short to positive |
Bmw | Battery temperature sensor circuit – electrical fault |
Buick | Ignition Control Circuit Group 1 |
Cadillac | Ignition control module (ICM) bank 1 -circuit malfunction |
Chevrolet | Ignition Control Circuit Group 1 |
Ford | Spark Output Circuit Fault |
Gm | Ignition Coil Group 1 Control Circuit Conditions |
Honda | Camshaft position (CMP) sensor – top dead center sensor 1 – connector disconnection |
Isuzu | Crankshaft position (CKP) sensor - connector disconnection |
Land Rover | Spark advance signal – circuit malfunction |
Lincoln | Ignition system -spark output (SPOUT) signal -circuit malfunction |
Mazda | Engine control module (ECM) – loss of ignition output signal |
Mercedes-Benz | Cylinder cut-out system OFF, cylinder 2 -exhaust valve not opening |
Mercury | Spark Output Circuit Fault |
Oldsmobile | Ignition control module (ICM) bank 1 -circuit malfunction |
Volvo | Ignition coil, cylinder 5, primary – signal high |
Volkswagen | Ignition coil/amplifier, cylinder 2 - short to positive |
We have not gotten around to publishing a technical guide specifically for P1359 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
