P1358
BAT Team
Manufacturer Specific Definitions for P1358
AudiIgnition coil/amplifier, cylinder 2 - open circuit
BmwBattery temperature sensor circuit – electrical fault
BuickIgnition Control Module Output High/Pulse Detected When Grounded Cylinder 8
CadillacIgnition Control Module Output High/Pulse Detected When Grounded Cylinder 8
ChevroletIgnition Control Module Output High/Pulse Detected When Grounded Cylinder 8
Daewoo#8 Misfire Circuit - Short
FordIgnition Diagnostic Monitor Signal Out of Self-Test Range
GmIgnition Control Module Output High/Pulse Detected When Grounded Cylinder 8
Hyundai#8 MF Signal Line Open
Land RoverIgnition diagnostic module – range/   performance problem
LincolnIgnition system diagnostic monitor -out of self-test range
MazdaEngine control module (ECM) -loss of ignition diagnostic monitor
Mercedes-BenzCylinder cut-out system OFF, cylinder 5 -exhaust valve not opening
MercuryIgnition Diagnostic Monitor Signal Out of Self-Test Range
VolvoIgnition coil, cylinder 5, primary – signal low
VolkswagenIgnition coil/amplifier, cylinder 2 - open circuit
We have not gotten around to publishing a technical guide specifically for P1358 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
