P1357
Manufacturer Specific Definitions for P1357
Audi | Ignition coil/amplifier, cylinder 1 - short to ground |
Bmw | Idle speed control (ISC) actuator - malfunction |
Buick | Ignition Control Module Output High/Pulse Detected When Grounded Cylinder 7 |
Cadillac | Ignition Control Module Output High/Pulse Detected When Grounded Cylinder 7 |
Chevrolet | Ignition Control Module Output High/Pulse Detected When Grounded Cylinder 7 |
Daewoo | #7 Misfire Circuit - Short |
Ford | Ignition Diagnostic Monitor Pulsewidth Not Defined |
Gm | Ignition Control Module Output High/Pulse Detected When Grounded Cylinder 7 |
Hyundai | #7 MF Signal Line Open |
Land Rover | Ignition diagnostic module |
Lincoln | Ignition Diagnostic Monitor Pulsewidth Not Defined |
Mercedes-Benz | Cylinder cut-out system ON, cylinder 2, 3, 5 or 8 – inlet valve still opening |
Mercury | Ignition Diagnostic Monitor Pulsewidth Not Defined |
Volvo | Ignition coil, cylinder 4, primary – signal high |
Volkswagen | Ignition coil/amplifier, cylinder 1 - short to ground |
We have not gotten around to publishing a technical guide specifically for P1357 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
