P1355
Manufacturer Specific Definitions for P1355
Audi | Ignition coil/amplifier, cylinder 1 - open circuit |
Bmw | Idle Speed Control Valve Open Solenoid Control Circuit Signal Low |
Buick | Ignition Control Module Output High/Pulse Detected When Grounded Cylinder 5 |
Cadillac | Ignition Control Module Output High/Pulse Detected When Grounded Cylinder 5 |
Chevrolet | Ignition Control Module Output High/Pulse Detected When Grounded Cylinder 5 |
Citroen | Ignition Coil D Primary Circuit Malfunction |
Daewoo | #5 Misfire Circuit - Short |
Ford | Ignition Coil 'D' Primary Circuit |
Gm | Ignition Control Module Output High/Pulse Detected When Grounded Cylinder 5 |
Honda | Intake side ignition coil – power supply circuit malfunction |
Hyundai | #5 MF Signal Line Open |
Lincoln | Ignition coil 4, primary -circuit malfunction |
Mazda | Ignition coil D – primary circuit malfunction |
Mercedes-Benz | Cylinder cut-out solenoid, bank 1 -solenoid stuck open |
Mini | Misfire Cylinder 7 With Fuel Cut-Off |
Oldsmobile | Ignition control module (ICM) -ignition coil 5circuit voltage high |
Peugeot | Ignition Coil D Primary Circuit Malfunction |
Volvo | Ignition coil, cylinder 3, primary- signal high |
Volkswagen | Ignition coil/amplifier, cylinder 1 - open circuit |
We have not gotten around to publishing a technical guide specifically for P1355 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
