P1354
Manufacturer Specific Definitions for P1354
Audi | Fuel quantity adjuster position sensor |
Bmw | Idle Speed Control Valve Open Solenoid Control Circuit Signal High |
Buick | Ignition Control Module Output High/Pulse Detected When Grounded Cylinder 4 |
Cadillac | Ignition Control Module Output High/Pulse Detected When Grounded Cylinder 4 |
Chevrolet | Ignition Control Module Output High/Pulse Detected When Grounded Cylinder 4 |
Citroen | Ignition Coil C Primary Circuit Malfunction |
Daewoo | #4 Misfire Circuit - Short |
Dodge | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor -implausible signal |
Ford | Ignition Coil 'C' Primary Circuit |
Freightliner | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor -implausible signal |
Gm | Ignition Control Module Output High/Pulse Detected When Grounded Cylinder 4 |
Hyundai | #4 MF Signal Line Open |
Kenworth | P1354 - VGT power supply low fault detected |
Lexus | Variable valve “timing system – RH bank – malfunction |
Lincoln | Ignition coil 3, primary -circuit malfunction |
Mazda | Ignition coil C – primary circuit malfunction |
Mini | Misfire During Start Cylinder 7 |
Oldsmobile | Ignition control module (ICM) -ignition coil 4circuit voltage high |
Peterbilt | P1354 - VGT power supply low fault detected |
Peugeot | Ignition Coil C Primary Circuit Malfunction |
Saab | Ignition diagnostic module, cylinder 4 – no signal |
Toyota | Variable valve timing system - RH bank - malfunction |
Volvo | Ignition coil, cylinder 3, primary – signal low |
Volkswagen | Fuel quantity adjuster position sensor |
We have not gotten around to publishing a technical guide specifically for P1354 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
