P1353
Manufacturer Specific Definitions for P1353
Bmw | Idle Speed Control Valve Closing Solenoid Control Circuit Electrial |
Buick | Ignition Control Module Output High/Pulse Detected When Grounded Cylinder 3 |
Cadillac | Ignition Control Module Output High/Pulse Detected When Grounded Cylinder 3 |
Chevrolet | Ignition control module (ICM) -ignition coil 3circuit voltage high |
Citroen | Ignition Coil B Primary Circuit Malfunction |
Daewoo | #3 Misfire Circuit - Short |
Ford | Ignition Coil 'B' Primary Circuit |
Gm | Ignition Control Module Output High/Pulse Detected When Grounded Cylinder 3 |
Hyundai | #3 MF Signal Line Open |
Land Rover | Ignition coil B, primary – circuit malfunction |
Lincoln | Ignition coil 2, primary -circuit malfunction |
Mazda | Ignition coil 8 – primary circuit malfunction |
Mini | Misfire Cylinder 6 With Fuel Cut-Off |
Oldsmobile | Ignition control module (ICM) -ignition coil 3circuit voltage high |
Peugeot | Ignition Coil B Primary Circuit Malfunction |
Saab | Ignition diagnostic module, cylinder 3 – no signal |
Volvo | Ignition coil, cylinder 2, primary – signal high |
We have not gotten around to publishing a technical guide specifically for P1353 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
