P1350
Manufacturer Specific Definitions for P1350
Audi | Ignition amplifier, primary circuit 3 - open circuit |
Bmw | Idle Speed Control Valve Closing Solenoid Control Circuit Signal High or Low |
Buick | Ignition control module (ICM) -electronic spark timing (EST)/ignition control (IC)/bypass circuit malfunction |
Cadillac | Ignition control module (ICM) -bypass line monitor circuit malfunction |
Chevrolet | Ignition control system, bypass monitor circuitmalfunction |
Citroen | Fuel Level Sensor B Intermittent/Bypass Line Monitor |
Dodge | Mass air flow (MAF) sensor range/performance |
Freightliner | Mass air flow (MAF) sensor range/performance |
Gm | Ignition Control System |
Isuzu | Variable Valve Timing System Fault Bank 2 |
Kenworth | P1350 - VGT status invalid fault detected |
Lexus | Variable valve timing sensor – RH bank – circuit malfunction |
Mini | Misfire During Start Cylinder 5 |
Oldsmobile | Ignition control module (ICM) -bypass line monitor circuit malfunction |
Peterbilt | P1350 - VGT status invalid fault detected |
Peugeot | Fuel Level Sensor B Intermittent/Bypass Line Monitor |
Pontiac | Ignition control system, bypass circuit -circuitmalfunction |
Saab | Ignition diagnostic module, random/multiple cylinder(s) – no signal |
Toyota | Variable valve timing sensor - RH bank - circuit malfunction |
Volvo | Ignition coil, cylinder 1, primary – signal low |
Volkswagen | Ignition amplifier, primary circuit 3 - open circuit |
We have not gotten around to publishing a technical guide specifically for P1350 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
