P1344
Reading P1344 on your car
P1344 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1344
| Make | Fault Location |
| Audi | Ignition amplifier, primary circuit 2 - short to positive |
| Bmw | Manifold differential pressure circuit, actuator 2 – mechanical fault |
| Daewoo | #4 Ion Circuit |
| Hyundai | #4 Ion Line Open |
| Mini | Misfire During Start Cylinder 2 |
| Saab | Cylinder 4 – misfire detected |
| Volkswagen | Ignition amplifier, primary circuit 2 - short to positive |
We have not gotten around to publishing a technical guide specifically for P1344 yet.
