P1333
Reading P1333 on your car
P1333 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1333
| Make | Fault Location |
| Bmw | Downstream Throttle Air Leak |
| Daewoo | #3 Misfire Circuit - Open |
| Hyundai | #3 MF Signal Line Short |
| Land Rover | Knock sensor (KS) 2, bank 2 – high input |
| Mini | Knock Sensor 4 High Input |
We have not gotten around to publishing a technical guide specifically for P1333 yet.
