P1326
Reading P1326 on your car
P1326 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1326
AcuraIgnition Control Module Combustion Quality Input Signal
AudiKnock control, cylinder 2 - control limit reached
DaewooGlow Relay - Stuck
HondaIgnition control module (ICM) - combustion quality input signal
HyundaiGlow Relay Stuck On
IsuzuIgnition control module (ICM) – combustion quality input signal
OpelKnock control,cylinder 1 - control limit reached
VolvoEngine control module (ECM), knock control detection – circuit offset
VolkswagenKnock control, cylinder 2 - control limit reached
We have not gotten around to publishing a technical guide specifically for P1326 yet.
