P1309
Reading P1309 on your car
P1309 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1309
CitroenMisfire Monitor AICE Chip Fault
DaewooIg. Coil 1 - Pf Mal
FordMisfire Detection Monitor Not enabled
HyundaiAcceleration Sensor Circuit High Input
KiaG-force sensor – signal high
LincolnMisfire monitor disabled
MazdaMisfire detection monitor – not enabled
MercuryMisfire monitor disabled
PeugeotMisfire Monitor AICE Chip Fault
SaabCamshaft position (CMP) actuator, LH – short circuit
We have not gotten around to publishing a technical guide specifically for P1309 yet.
