P1290
Manufacturer Specific Definitions for P1290
Audi | Engine coolant temperature (ECT) sensor, ECM controlled cooling system - high input |
Chrysler | Compressed natural gas pressure sensorpressure high |
Citroen | Cylinder Head Temp Sensor Low Input |
Dodge | Compressed natural gas pressure sensorpressure high |
Ford | Cylinder Head Temperature Sensor Signal Less Than Self-Test Range |
Honda | Throttle position (TP) motor - forced idle mode |
Hyundai | Pressure Limit Valve (DVB3) Error |
Infiniti | Throttle control motor relay – voltage low |
Isuzu | Throttle position (TP) motor -forced idle mode |
Land Rover | Cylinder head temperature – voltage low |
Lincoln | Cylinder head temperature (CHT) sensor -low input |
Mazda | Cylinder head temperature (CHT) sensor – circuit malfunction |
Mercury | Cylinder head temperature (CHT) sensor -low input |
Nissan | Throttle control motor relay – voltage low |
Peugeot | Cylinder Head Temp Sensor Low Input |
Plymouth | Compressed natural gas pressure sensor pressure high |
Ram | Compressed natural gas pressure sensorpressure high |
Volkswagen | Engine coolant temperature (ECT) sensor, ECM controlled cooling system - high input |
We have not gotten around to publishing a technical guide specifically for P1290 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
