P1288
Manufacturer Specific Definitions for P1288
Acura | Rocker Arm Oil Pressure Switch Circuit Low Voltage |
Audi | Turbocharger (TC) bypass valve - short to positive |
Bmw | Secondary Air Injection Pump With Series Resistor Control Circuit Electrical |
Buick | Accelerator Pedal Position Sensor 3 Circuit High Voltage |
Cadillac | Accelerator Pedal Position Sensor 3 Circuit High Voltage |
Chevrolet | Accelerator pedal position (APP) sensor 3voltage high |
Chrysler | Intake manifold air control solenoid (short runner) |
Citroen | Cylinder Head Temp Sensor Out Of Self Test Range |
Dodge | Intake manifold air control solenoid (short runner) |
Ford | Cylinder Head Temperature Sensor Out of Self-Test Range |
Gmc | Accelerator pedal position (APP) sensor 3 voltage high |
Gm | Accelerator Pedal Position Sensor 3 Circuit High Voltage |
Honda | Oil pressure switch, rocker arm -circuit low voltage |
Infiniti | Heated oxygen sensor (H02S), bank 2 – slow response |
Jeep | Intake manifold air control solenoid (short runner) -wiring open/short circuit |
Kenworth | P1288 - AMF CAN sensor supply voltage out of range |
Land Rover | Cylinder head temperature – range/ performance problem |
Lincoln | Cylinder head temperature (CHT) sensor -out of self-test range |
Mazda | Cylinder head temperature (CHT) sensor- out of self-test range |
Mercury | Cylinder head temperature (CHT) sensor -out of self-test range |
Mini | Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Signal Low |
Nissan | Heated oxygen sensor (H02S), bank 2 – slow response |
Peterbilt | P1288 - AMF CAN sensor supply voltage out of range |
Peugeot | Cylinder Head Temp Sensor Out Of Self Test Range |
Volkswagen | Turbocharger (TC) bypass valve - short to positive |
We have not gotten around to publishing a technical guide specifically for P1288 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
