P1287
Manufacturer Specific Definitions for P1287
Acura | Rocker Arm Oil Pressure Switch Circuit High Voltage |
Audi | Turbocharger (TC) bypass valve - open circuit |
Bmw | Secondary air injection (AIR), pump relay – signal low |
Buick | Accelerator Pedal Position Sensor 3 Circuit Low Voltage |
Cadillac | Accelerator Pedal Position Sensor 3 Circuit Low Voltage |
Chevrolet | Accelerator Pedal Position Sensor 3 Circuit Low Voltage |
Chrysler | Fuel Injection Pump Controller Supply Voltage Low Condition |
Citroen | Fuel Pulse In Range But Higher Than Expected |
Dodge | Fuel Injection Pump Controller Supply Voltage Low Condition |
Ford | Fuel Pulse In Range But Higher Than Expected |
Gmc | Accelerator pedal position (APP) sensor 3 voltage low |
Gm | Accelerator Pedal Position Sensor 3 Circuit Low Voltage |
Honda | Oil pressure switch, rocker arm – circuit high voltage |
Kenworth | P1287 - AMF CAN sensor pcb over temperature |
Land Rover | Engine fuel demand – range/performance problem |
Mini | Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Electrical |
Peterbilt | P1287 - AMF CAN sensor pcb over temperature |
Peugeot | Fuel Pulse In Range But Higher Than Expected |
Ram | Injection pump control module/engine control module (ECM) 1 -supply voltage low |
Volvo | Electronic throttle system (ETS) – range/performance problem |
Volkswagen | Turbocharger (TC) bypass valve - open circuit |
