P1286
Manufacturer Specific Definitions for P1286
Acura | Engine Oil Pressure Sensor Stuck Low |
Buick | Accelerator Pedal Position Sensor 3 Performance |
Cadillac | Accelerator pedal position (APP) sensor 3 rangeperformance |
Chevrolet | Accelerator pedal position (APP) sensor 3 range performance |
Chrysler | Accelerator Position Sensor Supply Voltage Too High |
Citroen | Fuel Pulse In Range But Lower Than Expected |
Dodge | Accelerator Position Sensor Supply Voltage Too High |
Ford | Fuel Pulse In Range But Lower Than Expected |
Gmc | Accelerator pedal position (APP) sensor 3 range performance |
Gm | Accelerator Pedal Position Sensor 3 Circuit Performance |
Honda | Oil pressure sensor, rocker arm – signal stuck low |
Infiniti | Heated oxygen sensor (H02S), bank 2 – activity |
Kenworth | P1286 - AMF CAN sensor defective |
Nissan | Heated oxygen sensor (H02S), bank 2- activity |
Peterbilt | P1286 - AMF CAN sensor defective |
Peugeot | Fuel Pulse In Range But Lower Than Expected |
Pontiac | Accelerator pedal position (APP) sensor 3 range performance |
Ram | Accelerator pedal position (APP) sensor -highinput |
Volvo | Electronic throttle system {ETS) – range/performance problem |
Volkswagen | Fuel Injection Air Control Valve Circuit Short To B+ |
We have not gotten around to publishing a technical guide specifically for P1286 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
I have a problem with my Nissan Armada 2007 V8 4×4 engine light ON. Connected my scanner LAUNCH X-431 found DTC P1286 A/F sensor 1 bank 2.stared diagnosis for this code. First checked for EXHAUST & INTAKE leaks found ok. I can’t check the fuel trim with this scanner but I can check the voltage variation of the sensor in bank1 sensor 1 and bank 2 sensor 1.
Bank 1 sensor 1 varies voltage form 0.75v to 5.02v in idle & throttle applied
Bank 2 sensor 1 no variation constant 1.50v in idle or throttle applied
I started to change OEM parts first oxygen sensor B2 sensor 1 still same. After checked wiring harness
For resistance, open, short to voltage, short to ground and continuity found ok.
Changed :
ECM, MAF SENSOR ,4 OXIGEN SENSOR,INTAKE MANIFOLD GASKET ,FUSE BOX,
I found on relearn procedure in the YouTube(idle ,engine switch off, remove MAF sensor connector, start engine 3sec switch off engine connect MAF sensor clear code idle for 10min) I tried it still the same
If I clear the DTC it will not come in idle. I have to drive the vehicle about 15km above 80km/h speed
Then stop the vehicle switch off the ignition 3 second after start the vehicle in idle Engine light comes on
DTC P1286 set in ECM. If I clear the code suddenly it will not come back have to drive few km ignition switch off and on. Yesterday another code set P1272 A/F sensor 1 bank1 (both code state showing 245)
Please help me to fix this issue
thankuuu
P1286 code— BMW 330d 245 ps 180kw 2009 baujahr ?
