P1283
Manufacturer Specific Definitions for P1283
BmwDiagnostic Module Tank Leakage Switching Solenoid Open Circuit
BuickAccelerator Pedal Position Sensor 2 Circuit High Voltage
CadillacAccelerator Pedal Position Sensor 2 Circuit High Voltage
ChevroletAccelerator pedal position (APP) sensor 2voltage high
ChryslerIdle Select Signal Invalid Condition
CitroenIPR Circuit Failure
DodgeIdle Select Signal Invalid Condition
FordFuel pressure regulator control solenoid -circuit malfunction
GmcAccelerator pedal position (APP) sensor 2 voltage high
GmAccelerator Pedal Position Sensor 2 Circuit High Voltage
HyundaiDirection Potentiometer Open (Low) - AUTO Defog
InfinitiHeated oxygen sensor (H02S), bank 2 – lean mixture
KenworthP1283 - AMF CAN sensor pulsation detected
MiniSwitching Solenoid for Air Assisted Injection Valves Bank 1 Control Circuit Electrical
NissanHeated oxygen sensor (H02S), bank 2 – lean mixture
PeterbiltP1283 - AMF CAN sensor pulsation detected
PeugeotIPR Circuit Failure
RamEngine control module (ECM) 1 -idle signal malfunction
SaturnAccelerator pedal position (APP) sensor 2 voltage high
We have not gotten around to publishing a technical guide specifically for P1283 yet.
To escalate the priority of this guide in our production queue, please let us know the specifics of your vehicle (make, model, year, miles, and engine) and make a $9.99 donation via the payment button below. We will follow up immediately with additional questions as needed and email you a detailed guide for your vehicle.
Please help support us and let us help you.
