P1273
BAT Team
Manufacturer Specific Definitions for P1273
AcuraAccelerator Pedal Position Sensor 1-3 Correlation
BuickAccelerator Pedal Position Sensor 1-3 Correlation
CadillacAccelerator Pedal Position Sensor 1-3 Correlation
ChevroletAccelerator pedal position (APP) sensor 1/3 –signal variation
ChryslerAlC compressor clutch control circuit 2 voltage high
CitroenCylinder #3 High To Low Side Open
DodgeAle compressor clutch, circuit 2 -voltage high
FordCylinder #3 High To Low Side Open
GmcAccelerator pedal position (APP) sensor 1/3signal variation
GmAccelerator Pedal Position Sensor 1-3 Correlation
HondaAccelerator pedal position (APP) sensor 1/3 - signal variation
InfinitiHeated oxygen sensor (H02S), bank 1 – lean mixture
IsuzuAccelerator pedal position (APP) sensor 1/3- signal variation
JeepAlC compressor clutch control circuit 2 (PCM) circuit high
LincolnInjector circuit, cylinder 3 -high to low side open
MazdaCylinder #3 High To Low Side Open
MercuryInjector circuit, cylinder 3 -high to low side open
NissanHeated oxygen sensor (H02S), bank 1 – lean mixture
PeugeotCylinder #3 High To Low Side Open
PontiacAccelerator pedal position (APP) sensor 1/3signal variation
RamA/C compressor clutch, circuit 2 -voltage high
VolvoElectronic throttle system {ETS)- malfunction
We have not gotten around to publishing a technical guide specifically for P1273 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
