P1272
Manufacturer Specific Definitions for P1272
Acura | Accelerator Pedal Position Sensor 2-3 Correlation |
Buick | Accelerator Pedal Position Sensor 2-3 Correlation |
Cadillac | Accelerator Pedal Position Sensor 2-3 Correlation |
Chevrolet | Accelerator pedal position (APP) sensor 2/3 -signal variation |
Chrysler | AlC compressor clutch control circuit 2 voltagelow |
Citroen | Cylinder #2 High To Low Side Open |
Dodge | Ale compressor clutch, circuit 2 -voltage low |
Ford | Cylinder #2 High To Low Side Open |
Gmc | Accelerator pedal position (APP) sensor 2/3signal variation |
Gm | Accelerator Pedal Position Sensor 2-3 Correlation |
Honda | Accelerator pedal position (APP) sensor 2/3 - signal variation |
Infiniti | Heated oxygen sensor (H02S), bank 1 – voltage high |
Isuzu | Accelerator pedal position (APP) sensor 2/3 – signal variation |
Jeep | A/C Clutch Control Circuit 2 Low |
Kenworth | P1272 - Increase in combustion in cylinder 4 relative to the others. |
Lincoln | . Injector circuit, cylinder 2 -high to low side open |
Mazda | Cylinder #2 High To Low Side Open |
Mercury | Injector circuit, cylinder 2 -high to low side open |
Nissan | Heated oxygen sensor (H02S), bank 1 – voltage high |
Peterbilt | P1272 - Increase in combustion in cylinder 4 relative to the others. |
Peugeot | Cylinder #2 High To Low Side Open |
Pontiac | Accelerator pedal position (APP) sensor 2/3signal variation |
Ram | A/C compressor clutch, circuit 2 -voltage low |
We have not gotten around to publishing a technical guide specifically for P1272 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
