P1246
Manufacturer Specific Definitions for P1246
Acura | Accelerator pedal position (APP) sensor 1 - circuit malfunction |
Audi | Injector needle lift sensor - range/performance problem |
Citroen | Alternator Load Input Failed |
Ford | Alternator Load Input Failed |
Honda | Accelerator Pedal Position Sensor 1 Circuit Malfunction |
Isuzu | Low Fuel Pressure Regulator Circuit Malfunction |
Jaguar | No cranking signal - high signal |
Kenworth | P1246 - Cylinder 2: Injector spill valve short circuit across injector |
Land Rover | Alternator, load input – circuit malfunction |
Lincoln | Altemator |
Mazda | Generator/regulator system – load input out of range |
Mercury | Alternator |
Mitsubishi | Engine control module (ECM) – processor fault |
Peterbilt | P1246 - Cylinder 2: Injector spill valve short circuit across injector |
Peugeot | Alternator Load Input Failed |
Saab | Intake manifold air control solenoid, inner flap- open circuit/short to ground |
Volkswagen | Injector needle lift sensor - range/ performance problem |
