P1245
Reading P1245 on your car
P1245 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1245
Alfa RomeoOutput Stage of ECU For Variable Valve Timing
AudiInjector needle lift sensor - short to ground
BuickIntake Plenum Switchover Valve
CadillacIntake Plenum Switchover Valve
ChevroletIntake Plenum Switchover Valve
CitroenAlternator Load Input Failed Low
FordAlternator Load Input Failed Low
GmIntake Plenum Switchover Valve
JaguarNo cranking signal - low signal
Land RoverAlternator, load input – voltage high
LincolnAlternator -low input
MazdaGenerator/regulator system – load input out of range
MercuryAlternator -low input
MitsubishiEngine control module (ECM) – RAM error
PeugeotAlternator Load Input Failed Low
SaabTurbocharger (TC) wastegate regulating valve- failsafe
SaturnIntake manifold air control solenoid -circuit malfunction
SubaruTurbocharger (TC) wastegate regulating valve – failsafe
VolkswagenInjector needle lift sensor - short to ground
We have not gotten around to publishing a technical guide specifically for P1245 yet.
