P1244
Manufacturer Specific Definitions for P1244
Acura | Closed throttle position (CTP) - insufficient |
Alfa Romeo | Purge Control Solenoid Or Circuit |
Audi | Injector 8 - open circuit |
Bmw | Diagnostic Module Tank Leakage Pump Control Circuit Signal Low |
Chevrolet | Injector 8 -circuit malfunction |
Citroen | Alternator Load Input Failed High |
Ford | Alternator Load Input Failed High |
Gmc | Injector 8 -circuit malfunction |
Gm | Injector 8 Output Circuit |
Honda | Closed Throttle Position Insufficient |
Jaguar | Barometric pressure (BARO) sensor, incorporated in ECM - range/performance |
Land Rover | Alternator, load input – voltage low |
Lincoln | Alternator -high input |
Mazda | Generator/regulator system – load input out of range |
Mercury | Alternator -high input |
Mini | Fuel Pump Emergency Shutoff |
Mitsubishi | Engine control module (ECM) – RAM error |
Peugeot | Alternator Load Input Failed High |
Saab | Turbocharger (TC) wastegate regulating valve – voltage low |
Subaru | Turbocharger (TC) wastegate regulating valve – voltage low |
Volkswagen | Injector Circuit Open Cylinder 8 |
We have not gotten around to publishing a technical guide specifically for P1244 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
