P1239
Reading P1239 on your car
P1239 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1239
AudiInjector 3 - open circuit
ChevroletInjector 6 -circuit malfunction
ChryslerEngine oil temperature (EOT) -temperature too low
CitroenSpeed Fuel Pump Positive Feed Fault
DodgeEngine oil temperature (EOT) -temperature too low
FordSpeed Fuel Pump Positive Feed Fault
GenesisActive Air Flap Motor Fault
GmcInjector 6 -circuit malfunction
InfinitiThrottle position (TP) – performance
IsuzuHigh Fuel Pressure System Fault
JeepEngine Oil Temperature Too Low
MazdaSpeed Fuel Pump Positive Feed
MitsubishiCrankshaft position (CKP) sensor – range/performance problem
NissanThrottle position (TP) – performance
PeugeotSpeed Fuel Pump Positive Feed Fault
PorscheFuel Injector Cylinder 3
RamEngine oil temperature (EOT) -temperature too low
VolkswagenInjector 3 - open circuit
We have not gotten around to publishing a technical guide specifically for P1239 yet.
