P1236
Manufacturer Specific Definitions for P1236
Bmw | Diagnostic Module Tank Leakage Pump Control Open Circuit |
Chevrolet | Injector 5 -circuit malfunction |
Citroen | Fuel Pump Control Out Of Range |
Ford | Fuel Pump Control Out of Range |
Genesis | Active Air Flap F/B Voltage Low |
Gmc | Injector 5 -circuit malfunction |
Hyundai | Active Air Flap F/B Voltage Low |
Infiniti | Throttle control motor – short circuit |
Lexus | Fuel high-pressure pump, bank 2 – circuit malfunction |
Lincoln | Fuel pump control -signal malfunction |
Mazda | Fuel Pump Driver Module Disabled or Off Line |
Mercedes-Benz | Supercharger (SC) clutch – malfunction |
Mercury | Fuel pump control -signal malfunction |
Mini | Fuel Pump Relay Activation |
Mitsubishi | Accelerator pedal position (APP) sensor B – malfunction |
Nissan | Throttle control motor – short circuit |
Peugeot | Fuel Pump Control Out Of Range |
Saab | Intake manifold air control solenoid, outer flap – open circuit/short to ground |
Toyota | High Pressure Fuel Pump Number 2 Circuit |
We have not gotten around to publishing a technical guide specifically for P1236 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
