P1235
Manufacturer Specific Definitions for P1235
Chevrolet | Injector 5 -circuit malfunction |
Citroen | Fuel Pump Control Out Of Range |
Ford | Fuel Pump Control Out of Range |
Genesis | Active Air Flap System Fail |
Gmc | Injector 5 -circuit malfunction |
Gm | Injector 5 Output Circuit |
Hyundai | Active Air Flap System Fail |
Infiniti | Throttle motor position sensor – learning problem, bank 2 |
Kenworth | P1235 - Turbo Speed Plausibility fault |
Land Rover | Fuel pump (FP) – range/performance problem |
Lexus | Fuel high-pressure pump, bank 1 – circuit malfunction |
Lincoln | Fuel pump control -signal malfunction |
Mazda | Fuel pump (FP) control – out of range |
Mercedes-Benz | Supercharger (SC) pressure – incorrect |
Mercury | Fuel pump control -signal malfunction |
Mitsubishi | Mass air flow (MAF) sensor – malfunction |
Nissan | Throttle motor pos tion sensor – learning problem, bank 2 |
Peterbilt | P1235 - Turbo Speed Plausibility fault |
Peugeot | Fuel Pump Control Out Of Range |
Toyota | High Pressure Fuel Pump Circuit |
