P1234
Manufacturer Specific Definitions for P1234
AcuraTurbocharger (TC) boost pressure sensor/manifold absolute pressure (MAP) sensor – signal correlation
BmwLeakage Diagnostic Pump Control Circuit Signal High
BuickInjector Circuit Cylinder 5 Intermittent
CadillacInjector Circuit Cylinder 5 Intermittent
ChevroletInjector Circuit Cylinder 5 Intermittent
ChryslerPedal Position Sensor 2 CKT Plausibility
CitroenFuel Pump Driver Module Off Line
DodgeAccelerator pedal position (APP) sensor 2 malfunction
FordFuel Pump Driver Module Disabled Or Off Line
FreightlinerAccelerator pedal position (APP) sensor 2malfunction
GmInjector Circuit Cylinder 5 Intermittent
InfinitiThrottle motor position sensor – learning problem, voltage low, bank 2
JeepPedal Position Sensor 2 CKT Plausibility
KenworthP1234 - Cylinder 5: Injector spill valve short circuit across injector
LincolnFuel system -malfunction
MazdaFuel Pump Driver Module Disabled Or Off Line
MercuryFuel system -malfunction
MiniFuel Pump Relay Activation
MitsubishiThrottle position (TP) sensor B – malfunction
NissanThrottle motor position sensor – learning problem, voltage low, bank 2
PeterbiltP1234 - Cylinder 5: Injector spill valve short circuit across injector
PeugeotFuel Pump Driver Module Off Line
VolvoTurbocharger (TC) boost pressure sensor – boost control malfunction
We have not gotten around to publishing a technical guide specifically for P1234 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
