P1230
Manufacturer Specific Definitions for P1230
Audi | Injector 6 - short to ground |
Bmw | Leakage Diagnostic Pump Control Circuit Signal Low |
Citroen | Fuel Pump Low Speed Malfunction |
Daewoo | Fuel pump relay- voltage low |
Ford | Low Speed Fuel Pump Fault Condition |
Genesis | Low Pressure Fuel Pump Malfunction |
Hyundai | Slow Duty Solenoid |
Kenworth | P1230 - Cylinder 1: Injector spill valve short circuit across injector |
Land Rover | Fuel pump (FP) relay – open circuit |
Lincoln | Fuel pump/variable load control module -circuitintermittent |
Mercury | Low Speed Fuel Pump Fault Condition |
Mini | Fuel Pump Relay Activation |
Opel | Engine control relay - voltage low |
Peterbilt | P1230 - Cylinder 1: Injector spill valve short circuit across injector |
Peugeot | Fuel Pump Low Speed Malfunction |
Porsche | Fuel Injector Cylinder 6 |
Saab | Throttle position (TP) sensor 1 & 2 – range/performance problem |
Subaru | Fuel pump (FP) control module – circuit malfunction |
Volvo | Mass air flow (MAF) sensor -signal low |
Volkswagen | Injector 6 - short to ground |
