P1228
Manufacturer Specific Definitions for P1228
Audi | Injector 4 - short to ground |
Buick | Injector Circuit Cylinder 3 Intermittent |
Cadillac | Injector Circuit Cylinder 3 Intermittent |
Chevrolet | Injector Circuit Cylinder 3 Intermittent |
Citroen | Wastegate Failed Open (Under Pressure) |
Ford | Wastegate Failed Open Under Pressure |
Gm | Injector Circuit Cylinder 3 Intermittent |
Infiniti | Accelerator pedal position (APP) sensor 2 – voltage high |
Kenworth | P1228 - Cylinder 4 5 or 6: Injector needle valve high side short circuit to battery voltage |
Lamborghini | Fuel injector 4 circuit low voltage |
Nissan | Accelerator pedal position (APP) sensor 2 – voltage high |
Peterbilt | P1228 - Cylinder 4 5 or 6: Injector needle valve high side short circuit to battery voltage |
Peugeot | Wastegate Failed Open (Under Pressure) |
Porsche | Fuel Injector Cylinder 4 |
Toyota | Fuel Pump Malfunction |
Volkswagen | Injector 4 - short to ground |
We have not gotten around to publishing a technical guide specifically for P1228 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
