P1223
Manufacturer Specific Definitions for P1223
Alfa Romeo | HO2S Regulator Inner Adjuster Reaches Minimum Or Maximum Value of Correction |
Audi | Cylinder Shut Off Exhaust Valves Open Circuit |
Bmw | Leakage Diagnostic Pump Control Open Circuit |
Chevrolet | Injector 1 -circuit malfunction |
Citroen | Pedal Demand Sensor B Circuit High Input |
Dodge | Injector Output Circuit |
Ford | Pedal Demand Sensor B Circuit High Input |
Genesis | Oil Pump Solenoid Control Circuit High |
Gmc | Injector 1 -circuit malfunction |
Gm | Injector 1 Output Circuit |
Infiniti | Throttle position (TP) sensor 2 -voltage low |
Kenworth | P1223 - Cylinder 4: Injector needle valve low side short circuit to ground |
Lincoln | Pedal Demand Sensor B Circuit High Input |
Mahindra | Check Of Missing Injector Adjustment Value Programming |
Mini | Pedal Position Sensor 2 High Input |
Nissan | Throttle position (TP) sensor 2 – voltage low |
Peterbilt | P1223 - Cylinder 4: Injector needle valve low side short circuit to ground |
Peugeot | Pedal Demand Sensor B Circuit High Input |
Volkswagen | Cylinder Shut Off Exhaust Valves Open Circuit |
We have not gotten around to publishing a technical guide specifically for P1223 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
