P1219
Reading P1219 on your car
P1219 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1219
AudiInjector 7 - short to positive
BuickThrottle Position Sensor Refernce Voltage
CadillacThrottle Position Sensor Refernce Voltage
ChevroletThrottle Position Sensor Reference Voltage
CitroenCID Low
FordCID Stuck Low
GmThrottle Position Sensor Reference Voltage
KenworthP1219 - Cylinder 2: Injector needle valve low side short circuit to ground
PeterbiltP1219 - Cylinder 2: Injector needle valve low side short circuit to ground
PeugeotCID Low
VolkswagenInjector Circuit Cylinder 7 Short To Positive
We have not gotten around to publishing a technical guide specifically for P1219 yet.
