P1218
Reading P1218 on your car
P1218 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1218
AudiInjector 6 - short to positive
BuickInjection Pump Calibration Circuit
CadillacInjection Pump Calibration Circuit
ChevroletInjection Pump Calibration Circuit
CitroenCID High
DodgeRadiator Temperature Sensor Volts Too High
FordCID High
GmcFuel injection pump calibration resistor-circuit malfunction
GmInjection Pump Calibration Circuit
KenworthP1218 - Cylinder 2: Injector needle valve short circuit across injector
PeterbiltP1218 - Cylinder 2: Injector needle valve short circuit across injector
PeugeotCID High
PorscheFuel Injector Cylinder 6
VolkswagenInjector 6 - short to positive
We have not gotten around to publishing a technical guide specifically for P1218 yet.
