P1215
Reading P1215 on your car
P1215 is a manufacturer-specific code. Most inexpensive Bluetooth adapters read generic engine codes only and cannot reach these systems at all – reading it, and getting the manufacturer’s own description of the fault, needs a scanner that talks to the other modules.
Manufacturer Specific Definitions for P1215
AudiInjector 3 - short to positive
BmwCatalyst temperature sensor – wrong code
BuickGenerator Driver Circuit Conditions
CadillacGenerator Driver Circuit Conditions
ChevroletGenerator Driver Circuit Conditions
CitroenPedal Position Sensor C Circuit Low Input
FordPedal Position Sensor 'C' Circuit Low Input
GmGenerator Driver Circuit Conditions
KenworthP1215 - Cylinder 6: Injector needle valve low side short circuit to ground
LamborghiniFuel injector 3 circuit high voltage
LexusElectronic Driving Unit Circuit
MiniFuel Pump
PeterbiltP1215 - Cylinder 6: Injector needle valve low side short circuit to ground
PeugeotPedal Position Sensor C Circuit Low Input
PorscheFuel Injector Cylinder 3
SaturnEngine control module (ECM), ground detection -malfunction
ToyotaElectronic Driving Unit Circuit
VolkswagenInjector 3 - short to positive
We have not gotten around to publishing a technical guide specifically for P1215 yet.
