P1212
Manufacturer Specific Definitions for P1212
Alfa Romeo | Idle Throttle Switch Or Circuit |
Buick | Mass Air Flow Circuit Intermittent Low |
Cadillac | Mass Air Flow Circuit Intermittent Low |
Chevrolet | Mass Air Flow Circuit Intermittent Low |
Citroen | Injector Control Pressure Not Detected During Crank |
Dodge | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor 2, bank 1range/performance |
Ford | Injector Control Pressure Not Detected During Crank |
Freightliner | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor 2, bank 1 range/performance |
Gm | Mass Air Flow Circuit Intermittent Low |
Infiniti | ABS/TCS control module – circuit malfunction |
Kenworth | P1212 - Cylinder 3: Injector needle valve low side short circuit to battery voltage |
Nissan | ABS control module/traction control module – communication failure |
Peterbilt | P1212 - Cylinder 3: Injector needle valve low side short circuit to battery voltage |
Peugeot | Injector Control Pressure Not Detected During Crank |
Saab | Idle air control (lAC) valve – high output |
