P1211
Manufacturer Specific Definitions for P1211
Alfa Romeo | Battery Voltage Incorrect |
Audi | Intake Valves For Cylinder Shut Off Open Circuit |
Buick | Mass Air Flow Circuit Intermittent High |
Cadillac | Mass Air Flow Circuit Intermittent High |
Chevrolet | Mass Air Flow Circuit Intermittent High |
Citroen | Injector Control Pressure Sensor Above / Below Desired |
Dodge | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor 2, bank 1 range/performance |
Ford | Injector Control Pressure Sensor Above / Below Desired |
Freightliner | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor 2, bank 1 range/performance |
Gm | Mass Air Flow Circuit Intermittent High |
Infiniti | ABS/TCS control module – communication malfunction |
Kenworth | P1211 - Cylinder 3: Injector needle valve low side short circuit to ground |
Nissan | ABS control module – malfunction |
Peterbilt | P1211 - Cylinder 3: Injector needle valve low side short circuit to ground |
Peugeot | Injector Control Pressure Sensor Above / Below Desired |
Saab | Idle air control (lAC) valve – low output |
Volkswagen | Intake Valves For Cylinder Shut Off Open Circuit |
