P1210
Manufacturer Specific Definitions for P1210
Audi | Intake Valves For Cylinder Shut Off Short to B+ |
Citroen | Injector Control Pressure Above Expected Level |
Dodge | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor 2, bank 1 range/performance |
Ford | Injector Control Pressure Above Expected Level |
Freightliner | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor 2, bank 1range/performance |
Infiniti | Traction control system - malfunction |
Kenworth | P1210 - Cylinder 3: Injector needle valve short circuit across injector |
Nissan | Traction Control System Signal Circuit |
Peterbilt | P1210 - Cylinder 3: Injector needle valve short circuit across injector |
Peugeot | Injector Control Pressure Above Expected Level |
Volkswagen | Intake Valves For Cylinder Shut Off Short to B+ |
