P1207
Manufacturer Specific Definitions for P1207
Audi | Injector 7 - circuit malfunction |
Dodge | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor 1, bank 1 range/performance |
Freightliner | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor 1, bank 1 range/performance |
Kenworth | P1207 - Cylinder 5: Injector needle valve low side short circuit to ground |
Land Rover | Injector – cylinder 7 – open/short circuit to ground |
Peterbilt | P1207 - Cylinder 5: Injector needle valve low side short circuit to ground |
Saab | Injector air control solenoid – voltage low |
Subaru | Injector air control solenoid – voltage low |
Volkswagen | Fuel Injector Circuit Cylinder 7 Electrical Malfunction |
We have not gotten around to publishing a technical guide specifically for P1207 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
