P1206
Manufacturer Specific Definitions for P1206
Acura | Cylinder No. 6 - misfire |
Audi | Injector 6 - circuit malfunction |
Citroen | Injector Circuit Open / Shorted - Cylinder #6 |
Dodge | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor 1, bank 1range/performance |
Freightliner | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor 1, bank 1 range/performance |
Honda | Fuel System Failure Caused No. 6 Cylinder Misfire |
Isuzu | Injector Circuit Open / Shorted Cylinder #6 |
Jaguar | Injector - cylinder 6 - short circuit/open circuit |
Kenworth | P1206 - Cylinder 5: Injector needle valve short circuit across injector |
Land Rover | Injector- cylinder 6 – open/short circuit to ground |
Mahindra | Injector Chip Error |
Peterbilt | P1206 - Cylinder 5: Injector needle valve short circuit across injector |
Peugeot | Injector Circuit Open / Shorted - Cylinder #6 |
Saab | Secondary air injection (AIR) pump relay – low output |
Volkswagen | Injector 6 - circuit malfunction |
We have not gotten around to publishing a technical guide specifically for P1206 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
