P1203
BAT Team
Manufacturer Specific Definitions for P1203
AcuraCylinder No. 3 - misfire
AudiInjector 3 - circuit malfunction
BuickGas Mass Sensor Circuit High Frequency
CadillacGas Mass Sensor Circuit High Frequency
ChevroletGas Mass Sensor Circuit High Frequency
CitroenInjector Circuit Open / Shorted - Cylinder #3
DodgeCrankshaft position (CKP) sensor/camshaft position (CMP) sensor 2, bank 2 range/performance
FreightlinerCrankshaft position (CKP) sensor/camshaft position (CMP) sensor 2, bank 2 range/performance
GmGas Mass Sensor Circuit High Frequency
HondaFuel System Failure Caused No. 3 Cylinder Misfire
IsuzuInjector Circuit Open / Shorted Cylinder #3
JaguarInjector - cylinder 3 - short circuit/open circuit
KenworthP1203 - Cylinder 1: Injector needle valve low side short circuit to ground
Land RoverInjector – cylinder 3 – open/short circuit to ground
MahindraMinimum Rail Pressure Check Failed Due To Less Rail Pressure
PeterbiltP1203 - Cylinder 1: Injector needle valve low side short circuit to ground
PeugeotInjector Circuit Open / Shorted - Cylinder #3
VolkswagenInjector 3 - circuit malfunction
We have not gotten around to publishing a technical guide specifically for P1203 yet. To escalate the priority of this guide in our production queue, we appreciate a $9.99 donation. We will publish a guide within 30 days of payment.
