P1202
Manufacturer Specific Definitions for P1202
Acura | Cylinder No. 2 - misfire |
Audi | Injector 2 - circuit malfunction |
Buick | Gas Mass Sensor Circuit Low Frequency |
Cadillac | Gas Mass Sensor Circuit Low Frequency |
Chevrolet | Gas Mass Sensor Circuit Low Frequency |
Citroen | Injector Circuit Open / Shorted - Cylinder #2 |
Dodge | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor 2, bank 2range/performance |
Freightliner | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor 2, bank 2range/performance |
Gm | Gas Mass Sensor Circuit Low Frequency |
Honda | Fuel System Failure Caused No. 2 Cylinder Misfire |
Isuzu | Injector Circuit Open / Shorted Cylinder #2 |
Jaguar | Injector - cylinder 2 - short circuit/open circuit |
Kenworth | P1202 - Cylinder 1: Injector needle valve short circuit across injector |
Land Rover | Injector – cylinder 2 – open/short circuit to ground |
Mahindra | Number Of Injections Limited By Runtime |
Peterbilt | P1202 - Cylinder 1: Injector needle valve short circuit across injector |
Peugeot | Injector Circuit Open / Shorted - Cylinder #2 |
Volkswagen | Injector 2 - circuit malfunction |
Pick-up problem
Buona sera. Non sempre ma sotto 1800 giri il motore funzio come un iniettore difettasse superato i 1800 giri gira normale e avlte a minimo motere vbra come un iniettore non funzionasse ho cambiato sensore commrail senso fase pulito dibimetro ma il difetto persiste grazie
