P1197
Manufacturer Specific Definitions for P1197
Audi | Heated oxygen sensor (HO2S) 1, Bank 2, heater circuit malfunction |
Bmw | Secondary Air System Bank 2 |
Chrysler | Heated oxygen sensor (H02S) 2, bank 1 slow response |
Citroen | Key Off Voltage Low |
Dodge | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor 1, bank 2range/performance |
Ford | Key Off Voltage Low |
Freightliner | Crankshaft position (CKP) sensor/camshaft position (CMP) sensor 1, bank 2range/performance |
Infiniti | Low Input From Fuel Level Sensor |
Jeep | Heated oxygen sensor (H02S) 2, bank 1 slow response |
Kenworth | P1197 - Rail pressure gradient fault |
Mini | Differential Pressure Sensor Intake Manifold Signal |
Nissan | Low Input From Fuel Level Sensor |
Peterbilt | P1197 - Rail pressure gradient fault |
Peugeot | Key Off Voltage Low |
Plymouth | Heated oxygen sensor (H02S) 2, bank 1 -slowresponse |
Ram | Heated oxygen sensor (M02S) 2, bank 1 slow response |
Volkswagen | Heated oxygen sensor (HO2S) heater circuit malfunction |
